Need help fast UMI TM Adj. TA clunking
Alright Got my UMI ADJ. Tunnel mounted TA w DS loop on it vibrated alot it was set at -4 and the DS Was at 0, with the front of the TA mounted in the top hole. The I redid the pinion angle DS Still at 0 and adjusted the TA to -2. Now it hardly vibrates but when I get in and off the gas I hear/feel a clunk and its not the exhaust hitting anything. Also Took it through some twisties and it felt like the axle want to wrap/bind.
Should I drop the front of the TA into the middle hole on the bracket and reset it back to -2???? Is the top hole Not the right one?
I really need help here its my DD.
