Sportline and Koni's or stock and Koni's
I bought some Koni SA's and they had the sportline spring on them, i have both front and rear but the front is already set up. Should take the sportlines off and install my stock springs? Or what if i just the the front springs with my stock rears.
Also what do you recommend my initial settings be on the Koni's? Thanks
I would put the stockers back on and use the lower pertch up front and then hose mod the rears. This will give you some drop without slamming your car. As for settings most shoot for around 4 to 6 sweeps from full soft in the front and full soft to 1 turn from full soft in the rear. Mine are set 5 sweeps front 2 sweeps in the rear right now and the rear of my car is alittle harsh unless i'm on the interstate.
