WS6 Bushing Part Numbers
2000 WS6 A4 convertible (in case that matters):
The time has come to start replacing suspension bushings, especially in the rear and I need to know the various part numbers. I don't have a lot of $$$ these days and am just looking for a temporary fix (pronounced: "quality, affordable") until I can afford the good stuff.
I heard Moog made good rubber bushings for LCA's, and that there are some areas where you should use poly and others where rubber is the only real option. I thought I saw somewhere that you could buy a complete kit if you were using stock components.
As I understand it, the WS6 uses bigger bars than the standard Firebird, which tells me I need different part numbers. I hate going to a part store and getting the wrong part because they don't know the difference between a Firebird and a Trans Am. Even more, I hate getting it home and all torn apart before I find that out...
Where can I get a complete list of part numbers for all suspension bushings front and rear? Also, any suggestions as to affordable, quality parts would be greatly appriciated.
https://ls1tech.com/forums/suspension-brakes/939762-how-install-lower-control-arm-moog-bushings.html
info on moog lca bushings
