abs help asap NEEDED!!!
Old 09-22-2008, 06:54 PM
rudyzturbota's Avatar
Default abs help asap NEEDED!!!
i deleted my abs unit with abs delete kit. now the pedal wont stay firm after bleeding the brakes. should i need a manual master cylinder or will my stock one work fine.
i have a brand new abs master cylinder on the car. an i have no leaks.
Old 09-23-2008, 06:25 AM
do i need another new one, could my one from oriellys be just a bad one?
Old 09-23-2008, 08:48 AM
Major_Lee_Slow's Avatar
Did you bench bleed the master cylinder? It's amazing how much air it can hold. I bought a nice kit from Murry's to bench bleed mine. It has couple of fitting that tread into the master cylinder brake line holes and comes with a couple of hoses that are then routed back into the master. Then just pump the master's piston in and out until there are no more bubbles. Leave the hoses on until you get ready to reattach the brake lines so that no air can re-enter the system.
The re-bleed the entire system.
Old 09-23-2008, 04:55 PM
will i got a new master today, hopefully it works.
Old 09-23-2008, 06:28 PM
Make sure you bench bleed it before putting it on.
Old 09-24-2008, 05:23 AM
kind of curious, why? why must i bench bleed it. a friend of mine said he had to put a new one on his, an when he did he never bench bleed it. he just pour the fluid in an crack open all the bleeders, front an rear, an just kept the fluid full in the master cylinder.
now the problem im having now is ive put fluid in it an there isnt any bleeding out of the master with the lines disconnected. what am i overlooking? its a re manufacture not new, the guys at oriellys told me they dont offer a new one. any suggestions???
