Help P0107
Old 01-24-2009, 04:47 PM
817Borla's Avatar
Default Help P0107
im getting the code P0107 Manifold Absolute Pressure/Barometric Pressure Circuit Low Input.
i replaced the sensor but still get the code, car wont start it sputters/misses but wont start any help?
i just did H/C swap, wire mod and coil pack relocation if that helps.
Thanks
Old 01-24-2009, 05:13 PM
8 Sec Tuner
Mike TexaSS's Avatar
Check to see if the map sensor is connected.
Check to see if its in the back of the intake.
Old 01-24-2009, 05:39 PM
817Borla's Avatar
sensor is connected and in its right place, still nothing.
Old 01-24-2009, 06:11 PM
8 Sec Tuner
Check the fuse box under the hood. Look at the Eng Sen fuse.
Check for a huge intake leak. Try looking at A/C line on back of intake and the brake booster hose.
Old 01-24-2009, 07:03 PM
817Borla's Avatar
ill check those tomorrow, also earlier when i was trying to start the car the MAP sensor flew out lol.
Old 01-24-2009, 11:01 PM
Manic Mechanic's Avatar
You've got some firing order mistakes. You're igniting fuel into your intake lol.
Check the wiring to and from the coils, make sure they are wired for the cylinder they are firing.
Vernon
Old 01-24-2009, 11:25 PM
817Borla's Avatar
Vernon
thanks will do.
Old 01-25-2009, 10:37 AM
817Borla's Avatar
eng sen fuse is good, no intake leaks and everything is plugged in where it goes,
but im still getting that dam code. What else could it be???
Old 01-25-2009, 04:10 PM
8 Sec Tuner
unhook the battery it could be a history code.
Old 01-25-2009, 05:48 PM
Is the sensor connected to the correct plug? I worked on a truck last week and found the hood light plugged into an emissions solenoid.
Vernon
Old 01-25-2009, 08:53 PM
817Borla's Avatar
fixed i unhooked the battery for a while then she started up heres a quick video
its open headers btw.
http://www.youtube.com/watch?v=nyo9aTJXSGg
Quick Reply: Help P0107
