Engin code help!!!
Engin code help!!!
So I went to get a code checked and i came up with a few, there were 3 that were all secondary air injection...
Then there was a big one, i belive it said 1412 sever unkown, and the guy told me that i had to take it to the dealership to get that code pulled.
So i was wondering if any of yall knew what it was?
thanks alex
thanks alex
Not seeing any 1412 trouble code in my book, now there is a Code 14 if it's an OBD1 car, but I'm assuming it's an OBD2 car, and the closest ones I see listed in my book are P0112 (Intake air temp circuit, low input) P0412 (secondary air injection solenoid circuit)...other than those I have no idea
its a 99 ta ls1 lol.. should have included it... Yea i might have the numbers slightly off, it was a 14 something it might have been 1425... ill go get it rechecked in the morning, to get the right number...
here is all the 14xx codes
· P1403 - Exhaust Gas Recirculation System Valve 1
· P1404 - Exhaust Gas Recirculation (EGR) Closed Position Performance
· P1405 - Exhaust Gas Recirculation System Valve 3
· P1406 - EGR Valve Pintle Position Circuit
· P1407 - EGR Air Intrusion in Exhaust Supply to EGR Valve
· P1408 - Intake Manifold Pressure Sensor Circuit
· P1409 - EGR Vacuum System Leak
· P1410 - Fuel Tank Pressure System
· P1415 - Secondary Air Injection (AIR) System Bank 1
· P1416 - Secondary Air Injection (AIR) System Bank 2
· P1418 - Secondary Air Injection System Relay A Control Circuit High
· P1420 - Intake Air Low Pressure Switch Circuit Low Voltage
· P1421 - Intake Air Low Pressure Switch Circuit High Voltage
· P1423 - Intake Air High Pressure Switch Circuit High Voltage
· P1431 - Fuel Level Sensor 2 Circuit Performance
· P1432 - Fuel Level Sensor 2 Circuit Low Voltage
· P1433 - Fuel Level Sensor 2 Circuit High Voltage
· P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
· P1442 - EVAP Vacuum Sw. High Voltage During Ign. On
· P1450 - Barometric Pressure Sensor Circuit
· P1451 - Barometric Press. Sensor Performance
· P1460 - Cooling Fan Control System
· P1480 - Cooling Fan 1 Control Circuit High
· P1481 - Cooling Fan Speed Sensor Circuit
· P1482 - Cooling Fan Speed Output Circuit
· P1483 - Engine Cooling System Performance
· P1484 - Cooling Fan System Performance
