Intake Question
Intake Question
I have a 5.3 Z71 and I have to change out the knock sensors. Since I will have the intake off already, would changing to a LS1 intake make a difference, or should I just stick with the stock truck intake? Trying to find ways to add a little things to help out the old motor.
Stock 5.3 makes more power than the ls1 intake because it has longer intake runners. Also you will have to go with a different belt assembly to run the ls1 intake. If you still want a lower pro/ more power intake go with after market.
