02 Fan wire?
Moderator
Coach if I read the wiring diagram correct (someone please double check me)
If you ground the signal wire coming out of the computer (red harness - pin #33 dark blue wire) will start the right cooling fan (controlled by relays 2 and 3). And if you ground out (blue harness - pin #42 dark green wire) will start the low speed left engine fan.
