My idle/neutral seems 'weak', any ideas?
Old 07-09-2009, 11:55 AM
Donohue96M6Z28's Avatar
Default My idle/neutral seems 'weak', any ideas?
Well, a few weeks ago I got my fuel pump and fuel filter swapped bc my car was bogging down bad. It fixed that problem, and then it started taking a few seconds to start. I took it back to the shop and they swapped in a "good" used regulator, and that seems to have fixed that problem...
Now to the new problem. Which may or may not be related to the work I had done...
My idle seems "weak", it has died a couple times when reversing/going into first. When I push on the clutch when driving, the car seems weak. Kind of hard to explain. Also, when I used to use the AC, my RPMS would raise(I think it was a tuning issue). It no longer does that. I think its related to my current issue. I have a fuel pressure gauge in the car, and it was reading 40 when I got the fuel pump changed(which wasnt accurate, the shops gauge showed 60). Now my gauge is reading 38, and when I accelerate, the fuel pressure is going down. Shouldnt it be going up?
Any help is appreciated.
Patrick.
Old 07-09-2009, 12:39 PM
03Sssnake's Avatar
What kind of hose did you use for the lines that connect the pump to the hardline (in the fuel basket). I replaced the fuel pump on a friends car and made the mistake of using "fuel ine" (goodyear) thinking it was ok for in the fuel tank applications...NEGATIVE, that **** deteriorated and collapsed after a week or two. Before it happened the idle was weak and the car did not seem to run as hard.
