Help with a Cam swap
Anybody in the Houston area be interested in making some extra money helping me swap out the cam in my truck? I'm pretty knowledgable mechanically and have done a lot of the work on the truck myself, but never done a cam swap before. I priced getting it done by a shop and the first quote was $2700, granted that included the cam and parts, BUT..... not happening. I'll be doing the heads at the same time but just need somebody for the cam, really just support knowledge, i'll be doing all the wrench turning, you can can just sit back, drink some beer and make some easy money. The truck is an '05 Z71 with a 5.3L.
Ez
The cam is e z, if you will have the heads off just watch the lifters so they dont fall in the crankcase. The timing cover,oil pump,and chain come off. The oil pump pick up bolt can easily be removed without pulling the pan.Just spin the cam by hand and pull it out being careful not to drag on the bearings when coming out.If you can do heads you can do cam also, just be damn sure to follow correct torque procedures(specifically the rocker bolts). Buy a new crank bolt and torque the **** out of it too. Its pretty straight forward to do.Now ive have skipped alot of the obvious steps that dont need to be mentioned for the sake of keeping it short.
