Question about a ford engine head gasket...
Heres a ford question for you guys... I did the head gaskets on an f150 with 4.2 v6. Yesterday I started it all up for the first time and it was all good except for a leaking thermostat gasket. So i fixed that and let it sit over night.
This morning i add water and start it up and right away i get water in oil. So i have two theories, one, the intake manifold is leaking into the oil valley because i jad to drill out one of the bolts and couldnt find a replacement to put back in. So it has a missing bolt in the center.
Or two, a bad head gasket because i didnt follow the torque sequence and instead of tightening to the recommended 36 lb ft i did 65. What do you guys think?
Im freaking pissed that i have to tear it apart again! Oh and when i started it up yesterday and today it never got hot so its not from over heating...
I hope you are right. I was thinking I could find a bolt to put in and try again.
heads are fresh from shop so those are ok. Ok the block is toast that would really be bad... how can I check for it once I get the heads back off? The gaskets are MLS which is apparently extremely sensitive to any debris getting in there and when I was installing the head bolts I got a little water out of the holes which probably had dirt in it. could that be it?
