Cyl 1 Misfire! Help!
Alright, I have searched and this is what I have done:
switched the #1 and #3 coils.
Switched the #1 and #2 Wires.
Checked all conections.
I am going to go up to Autozone tomorrow at 7 am and hook it up to the OBD2. If it changes cyl. then I know the problem, otherwise its a fouled plug or Bad injector. I am leaning to Ignition cause it smells rich. I just hope its not a broken valve spring or something.
I ran some Red Line fuel system cleaner through it Saturday, problem just started today (8 pm, 50 miles later). Oil is clean.
Any other suggestions???
THanks!
THanks!
Well, nevermind! I went and drove her around a bit, still ran like ***. Stopped and filled her up with some Fresh 93 and drove around some more will still poor results. I was about 1/2 throttle and it was like "F_ck You!" all stumbling and ****. Then all of the sudden, WHOA! Were sideways! She fixed herself and proved it by kicking the *** end out! Must have been a cloged fuel injector.
Blasted her up to 125 or so and ran as good as ever!
Whew, I can sleep tonite. Hope she runs that good on the way to the unvailing tomorrow night! Kick ***!
Cliff notes: Car was broke but then she decided to kick the tires and light the fires by almost making me slide into ditch!
