1994 project camaro
1994 project camaro
Suspension
BMR tubular k-memeber
BMR tubular upper and lower arms
new upper ball joints
lakewood boxed lca in the rear
hal shock 12 way adjustables in the front and rear.
hal springs in the front
v6 springs in the rear
BMR double adjustable chrommoly panhard bar.
Bmr th-350 tublar cross memeber.
Sphoon adjustable torqure are with rod ends single drive shaft loop.
6 point chrmooly roll bar from wolfe craft low slung bars.
Transmision
tci pro competition th-350 foward valve body
b&m pro ratchet shifter
and a boss hoss 4200 stall converter with ballon plates for n20.
tci sfi aproved flex plate
b&m shifter cable
Rear end
Stock rear with welded housing
new bearings and seals with richromond 3.42
soild pinion spacer
Brakes
stainless steel front brake lines
new rotors front and rear
new hawk pads front and rear
custom abs delete with proportioning valve and line lock.
the engine
3.50 stroke eagle crank
billet 4 bolt main cap conversion arp studs
eagle h-beam rods
-5cc srp pistons
srp head studs
mr. gasket thin head gaskets(.018)
comp r lifters
one piece chromoly pushrods
heavly ported lt1 one heads with manley valves and comp springs and retainers
cloyes true roller
1.6rr Aluminum
meilings hv oil pump
meilings pick up
meilings oil pump drive
comp cam picked to match engine spec
msd pro billet distrubuter
tall aluminum valve covers
motor plate from mad man motor sports
arp rocker studs
victory jr. intake converted over to fit lt1 heads(port matched)
in summary its a n20 motor
357cubic inchs
12.8-1 compression ratio
Exhaust
Pacesetters coated long tubes
Interior has been redone and is in race/street car fashion pictures can only discribe
the car is 90% complete all it needs is engine life supports systems (carb, cooling, and igniton. adrive shaft and some wheels and tires. youll need a cowl hood later in the build. car has lot of time and effort i infortunley wont get back some on the web have seen it in the development and know i dont half ***. ASking 4,000obo
Pictures are availbe apon request if you have questions call 281-635-2047 no calls after 8pm please.
Transmision
b&m shifter cable
Rear end
soild pinion spacer
Brakes
the engine
eagle h-beam rods
-5cc srp pistons
srp head studs
comp r lifters
cloyes true roller
1.6rr Aluminum
meilings pick up
arp rocker studs
357cubic inchs
Exhaust
very interested.. email pics to musclemotors@sbcglobal.net
posted a reply on camaroz28.com but never got a reply
