how hard would it be?
how hard is it to take off an ls6 intake mainfold and replace it with an ls1?
if its not hard, i will sell my ls6 intake manifold for $225+ ls1 intake manifold.
lmk.
lmk.
Are you gonna tell the guy it has the LS6 intake, if he asks?
Purge fuel rails with shaerder valve ,Just use a fuel line disconnect tool, disconnect the fuel line going in the the rails, Un bolt all eight bolts on the manifold and lift up..
Repeat reverse.
Takes about 30 min.
Repeat reverse.
Takes about 30 min.
Don't break the Oil Pressure sending switch that's behind the manifold. It's the first thing to break. Do a search. It's got the stupid pcv hose wrapped around it. It's cheap-*** plastic and breaks when you tug the manifold forward. Just a warning....But, it you break it, Champion Chevrolet's Parts dept is open on Saturday monrings if you break it.
brian
brian
