Security System Locked Up! help please
dunno if this is possible for you but anyone with hp tuners can tune it out for you, are your other choice is get the vats system bypassed by getting the chip on your key ohmed then splice a resistor of close resistance into the two WHITE wire going down the inside of the steering column under the plastic kick panel with the truk release button on it. hope it helps
