Help car bogging down at 40 mph??
Old 03-10-2008, 11:40 AM
mojolamar's Avatar
Default Help car bogging down at 40 mph??
2 nights ago I was driving my A4 and I pressed the gas down and it started to bog and then suddenly jumped to life like it normally drives. So I plugged in my diablo to check DTC's and I had errors in my maf and my spark plugs and rear o2's since I no longer have them b/c of my longtubes. So I cleaned my maf and changed all of my spark plugs and it's still doing it . Any ideas on whats going on? Thanks
Old 03-10-2008, 11:42 AM
Greed4Speed's Avatar
Fuel filter?
Old 03-10-2008, 11:47 AM
1970judge's Avatar
Try the filter see what that does.
Old 03-10-2008, 11:48 AM
mojolamar's Avatar
alright thank you homies
Old 03-10-2008, 11:49 AM
SuIcIdAlPoNtIaC's Avatar
maybe front o2's.
Old 03-10-2008, 12:47 PM
GunshotZ28's Avatar
Originally Posted by Greed4Speed
Fuel filter?
That's what I was thinking. I had the same problem with my '96 Z71.
Old 03-10-2008, 01:00 PM
redsox_ws6's Avatar
does it also drive shitty when it rains..in first gear?
Old 03-10-2008, 01:12 PM
mojolamar's Avatar
yes very much so redsox
Old 03-10-2008, 01:46 PM
Thats a sign that the muffler bearings are going out.
Old 03-10-2008, 01:47 PM
quickblade's Avatar
LOL.. you sure its not a sign of wheel bearings going out...
Old 03-10-2008, 05:38 PM
DarkhorSe_SS's Avatar
It's one of your front o2's.. Since you changed your plugs & cleaned up the maf then your o2's are the issue. I just replaced my front left o2 this wkend and same scenario like yours.. It bogs and then it jumps to life and drives normal. Since the change, no bogs or sputtering.
Old 03-10-2008, 05:45 PM
RickyMartinZ28's Avatar
Could be totally off, but could be your converter locking up, and when you press on the gas it unlocks and picks up speed....???? Mine does that.
-Rick
Old 03-10-2008, 06:08 PM
98Ztwenty8's Avatar
is it misfirin?
Old 03-10-2008, 07:29 PM
8 Sec Tuner
Mike TexaSS's Avatar
Check the ENG SEN fuse under the hood. If blown replace it. Use your Diablo to data log and see if the MAF is reading. And if you installed the headers I would double check the front 02's. Make sure that they are plugged in to the correct front o2 plug in the wiring harness not the rears. Also if you extended the front 02's make sure its wired correctly.
Old 03-10-2008, 07:52 PM
Grimlock's Avatar
Let us know what the turn out is.
Old 03-10-2008, 08:35 PM
redsox_ws6's Avatar
Oops sorry I didn't mean the handling I meant the car it self. I will repost with my problem so I don't hijack this thread.
Old 03-10-2008, 10:06 PM
ramairracer's Avatar
mine was doing the same thing i thought it was a cracked spark plug from the header install, it turned out where the 02 extension hooked up to the 02 it was full of water causing the sputtering and back fireing
Old 03-10-2008, 10:16 PM
redsox_ws6's Avatar
This is irrelevant to the post but what kinda springs are you on and shocks, how much was the drop?
Old 03-11-2008, 06:49 AM
T/A-Speedfreak's Avatar
At one time my car did the same thing. The engine fuse was blown. Replaced it but it wasn't long before it did it again. I then had to start looking into why the fuse was blowing.
It turned out to be the O2 wires on one side of the car had been pinched and were grounding(shorting) out.
Good luck.
Old 03-11-2008, 10:50 PM
mojolamar's Avatar
Thanks for all the replys I changed my fuel filter today and it seemed to help a lot but it still did it once after that so I call diablo and asked about which p codes to turn off for the rear o2's and did so, but it still did it again so I am going to check the fuse and front o2s and see if it's not those.. and thanks again for the help!
Quick Reply: Help car bogging down at 40 mph??
