1972 Procharged Nova SS Six Speed 850hp Pump Gas Monster
Year: 1972
Make: Chevrolet
Model: Nova
Price: $35000
Mileage: 4000
Private or Dealer Listing: Private Listing
Location (State): TN
Color: Orange
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Where to start? I built this car from a roller I traded my convetible Z28 Camaro for. I have a ton of hours in this car and it has some what evolved over the last 3 years. If you are wanting a 100 point show car look else where, If you want something that every one turns to look and see what is making all the noise, than this is the car for you. This car will make you an immediate attention *****. Its loud, but in a good way. I drove this car on 2 legs of the power tour and it got around 13 to 14 miles a gallon, not great but what 1000hp car gets 20+? I will post the details below of what all is done to this car but I am sure I will leave some stuff out. Why am I selling this car? I am an engineer by trade and I love building cars more than I do driving or racing them. I have built a bunch of different stuff in the last 10 years. I built this car for a reason. REHAB. Thats right I had a bad car accident in 2008. It almost killed me. On my road to recovery I figured what better way to get over totaling my 600+ hp GTO than build a 1000+ hp Nova. Most of the stuff is custom on this car and additional photos can be found in prochargers catalog and in the October 2010 issue of Super Chevy. Its the car on the Cover. I have been building the next car in my head and I am ready to pull the trigger on it. So this one has to go. See specs below. I will consider trades, NO boats or bikes.
The Good The Bad and The ugly.
Things about this car, I am going to come out and tell you everything you need to know right now. There is an insane amount of powder coat work on this car. Even the bell housing and rear motor plate are powder coated. Why did I have this done? IDK? The power steering pump whines at times. Why because the corvette never came with hydro boost and the pump don't like it. There is a small power steering leak at the steering box. I am 90% sure its an o-ring, Its not bad and does not leak all the time. when it does its only very little.The Paint is not perfect. It has a rock chip or 2 cause I drive the car, alot. The car a speed density tune in it. It can be slightly temperamental until it reaches operating temp. After that it is perfect. (Like any hot rod.) The fuel level sender has its good and bad days, its summit piece so a replacement is cheap. The blinkers do no work due to the fact the hazzard light switch is broken. The seats are fixed. They can be easily moved but I am the only person that ever drives and has driven the car. In a nut shell, This car is Loud and faster than most any thing you will ever drive. It has ran a best of 6.39 in the 1/8 at 108, on a set of slicks. Yes it corners and runs in a straight line. You can drive this car any where. It will not run hot and runs on pump gas. I repeat runs on 92 pump gas. It makes all this power on pump fuel. I have a dyno sheet for the car on a Dyno Dyanmics Load bearing Dyno on 18 psi of boost it makes 775 to the tires. The blower belt was slipping (8 rib belt) I have since replaced the blower drive with a 12 rib and it will make 20+ psi. I am sure this car will put down 850 to the tires with no belt slip. If you dont like attention, do not buy this car. I cant go anywhere in it with having a 30 min conversation about the car. There are a few small things wrong with the car, all are mentioned above. There are no surprises with this car. The body is solid with no rust, no patch panels, none. The orginal color on the car was gold. The car was painted when I got it. It looks good but is not perfect.
Motor Specs.
LQ4 cast Iron block
Stock crank (worked over by weber racing)
K1 forged Rods
Wiseco forged Pistons
ARP Mian Studs
Arp Head Studs
Cometic Gaskets
Stage 3 Patriot Performance 317 heads
Edelbrock Victor JR Manifold
Professional Products 90" elbow
92mm Billet Throttle Body
1 7/8 to 2 steep primary SS headers to 3 1/2 collectors
full mandral bent 3 1/2 exhaust thru super 44 flow masters with h pipe
(Exhaust is V banded so no gaskets and full exhaust can be removed from the car in less than 5 mins)
All the exhaust and the headers are full coated.
F1A Procharger (Set up for 22 psi of Boost) 12 Rib divorced Drive. (there is a 8 rib drive on it in the pics) but it now has a 12 Rib
3 1/2 Front Mounted intercooler
FSR Fabricated Radiator w/ (4) 9" electric fans, (Why Did I do 4 fans, They pull more cfm and less current draw than 2 normal size fans, also the cove more surface area and eliminate the need for a shroud, besides the look cool and are very not loud)
Corvette 140 amp Alternator
Corvette Powersteering Pump
Power Steering Cooler
All lines on this car are Aeroquip.
BRP Motor Mounts and Custom Fabricated Trans Crossmember.
Fuel System
15 gallon Fuel cell with sender
10 an feed line to Aeromotive A1000 pump
Aeromotive Pre and Post billet serviceable filters
Aeromotive Regulator
83 pound per hour injectors
8 an return line
Aeromotive Pump Controller.
Transmission and Rear End.
Camaro T56 6 speed Transmission (completely rebuilt with the usual upgrades)
Hurst Billet Plus Shifter
3" steel Drive shaft
8.5" gm 10 bolt rear. 31 spline axles and new Strange Pro Diff Posi. With 3.90 gear.
Moser C clip eliminators and TA performance Rear cover
Suspension and Brakes
2002 Camaro 12.5" Front Disk Brakes with Power Slot Rotors and Braided Brake Lines
1997 Camaro Rear Disc Brakes
CCP Billet Master Cylinder and Hydro Boost.
All new Brake lines front to rear
(You eat the dash every time you touch the brakes, they are that good.)
Global West Tubular upper and Lower Control Arms
Global west Billet Aluminum Body Bushings
Adjustable QA1 Coil Coil Overs
The Biggest Hotchkis Swap Bar made
Detroit Speed 2" Rear Drop Leafs and Billet Offset Shackles
QA1 Adjustable Rear Shocks
Caltracs
Detroit Speed Mini Tub Kit
Full roll cage installed in the car , its done correctly with NHRA specs. Its all custom bent and hides very well inside the car, Its all tucked up extremely tight.
Custom Subframe connectors.
Interior and Misc.
Kirky Light Weight Seats and Covers
New carpet and fully dyna matted interior, The interior is in excellent shape.
Auto Meter Carbon Fiber Gauges (Tach , Speedo, Boost, Oil Press, Fuel Press, Water Temp, Fuel Level and Voltage.)
Painless Chassis harness and Painless Engine Management Harness. All wiring is NEW.
Wheels are Boss Motor sports 18x8 and 18x10's with Nitto NT555s all around.
Let me know what you have to trade or just buy it.
ttt
prolly because novas look hidious!!!....lol...sorry. just my opinion.i only looked cause it said supercharged and was 35k dollars.id love to tool it around....but for that kind of loot you gotta find a certain someone,good luck.it is sweet for a nova
Thanks Guys
Damn, I don't even usually like those year/style Nova's (bigger fan of the earlier "box" shaped Nova), but that is a nice car.
Just wish my C5 was worth enough to offer up.....
Good luck with the sale, very nice work.
