Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
2002 Trans Am WS6 LS1
Old 01-31-2012, 09:42 AM
LS1Tech Platinum Sponsor
RacingJunk's Avatar
Exclamation 2002 Trans Am WS6 LS1
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $11500
Mileage: 0
Private or Dealer Listing: Dealer Listing
Location (State): IN
Color: Silver
LS Engine?: Car has LS engine
Located in Kokomo Indiana. Nice, real WS6. Car is silver, 6 speed trans, 66k miles. Car has many small but performance based mods. Has a adjustable clutch master (TICK), performance clutch (UNK), slotted rotors, slp air box, oil catch can, aluminum radiator, Magnaflow Cat back. Currently has a cut a/c line. I have new GM delco lines, new performance rear trailing arms, panhard bar and shock support. A replacment center console as it had a hole cut for an aftermarket fog light system, new gm floor mats, new spare clutch and fly wheel kit. New rear continental tires, fronts are fairly new also (Kumho). Comes with lS6 heads that have 8k miles, new yellow springs and spare clutch kit w/flywheel. Has had a retune but kinda sucks IMO. Old owner said it has a gm hot cam in it, which is why the a/c line was cut. Trans is starting to have the slight grind in 3/4 if you run it hard and hard only. Just started to grind and is either the shift fork or the pads. I have replacement steel shift fork and pads. Any issue the car has is still minor and I have all the parts to repair it, car is not ragged. Interior is dusty in pics from sitting in storage this year. Asking for the payoff from USAA and the parts are all on me. Also has a oil catch can in the pvc.
parts that need installed for 100% car and are INCLUDED:
3/4 steel shift fork (NEW)
Rear main seal (GM) (NEW)
a/c line if you desire a/c (GM) (NEW)
fog lights (in pass floor)
Extra parts that are INCLUDED with asking price:
799 heads w/8k miles
GM yellow springs (NEW)
Spare clutch kit w/ flywheel (NEW)
Console upper (USED)
Panhard, strut and rear bars / poly bushings (NEW)
Stock low mile 28 lbs injectors
MTI 220/220 Cam (USED)
LS2 timing set (GM) (NEW)
LS7 Lifters (GM) (NEW)
Gm LS6 valley Cover (NEW)
GM new knock sensors (NEW)
GM New Knock harness (NEW)
GM pvc tube for new cover (NEW)
GM Delco Plugs (NEW)
3/4 steel shift fork w/bronze (NEW)
3/4 aluminum keys (NEW)
A/C line if you desire a/c (GM) (NEW)
Car cover(NEW)
email me for more info..
http://www.racingjunk.com/Pontiac/24...html?aid=32630
