Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
92 bimini turbo hatch
Old 04-29-2012, 08:56 AM
sammy469's Avatar
Default 92 bimini turbo hatch
Year: 1992
Make: Ford
Model: Mustang
Price: $16000
Mileage: 57000
Private or Dealer Listing: Private Listing
Location (State): IL
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
92 Bimini Turbo Hatch!
1992 Bimini Blue Hatchback w/sunroof.
57k Miles on body RUST FREE!!!!
Original Paint. Paint is a solid 8.5 out of 10. A few scratches dings here and there! I think it's immaculate. To each his own.
New 93 Cobra Wing installed so whole hatch painted by Opher Autwurx. Hes DA MAN!
2 inch Cowl Fiberglass hood was on before i bought it in 07! Has Hood Pins. Hood still latches.
06 (FORD) Bullitts Chrome up front With Nittos 225/45/ZR17's. I have the other two wheels 17x8. No tires.
Rear has 15x10 Weld Prostars With 7.5 BS with MT ET street radials 275/60/15
5 lug with Racing studs Front and back.
Sold my 15" alumastars cause i was gonna get 17's. Never did lol!
New Black Carpet
Stock Leather seats
5 point Harness Driver and Passenger side.
JVC Head Unit With Aux and USB. Only front speakers Connected
My intensions on building this car were for the track so i tried to make it as light as possible. This car does not have AC or heat. Its Loud inside while driving. Car needs a full dyno tune. Car was tuned while i drove @ 17lbs with a buddy of mine that knows Fast XFI! This car is a beast at 17 lbs of boost! Tuned on 110. Aem controller is set to 16 or 17 lbs. I never touch it lol!. Car needs a fine Dyno tune for idling,startup and numbers ofcourse. Surges a lil after it warms up but not all the time and only in park. Car is fine and does not surge in gear. Like i said needs a full dyno tune. The alignment needs to be adjusted. Its not bad a buddy of mine put the bumpsteer kit on and its out of wack a lil. Cclips need to be resealed. A lot of people ask why are you selling this car? Well i lost interest and I lose interest in a lot of things and fast! Ive had a lot of toys and ready to move on to the next one. I am like a woman with shoes but toys lol. I also put a buddies car into a wall making a pass and walked away unharmed... not even a headache. Im not hurting for money and i will not let this go easy! This is a great price for this car and a steal as it sits! Its a tuff economy right now and hard to sell cars or buy for that matter that's why i have priced this thing at 16k. Please no tire kickers. If you think this is not fair then move on please i dont need anyones .02. Any other questions feel free to ask.IM LISTING FOR A BUDDY SO PLEASE NO PM'S,EMAIL ONLY...mr_i_catchn@hotmail.com. pics to come later. List of Parts below. Enjoy!NO TRADES!
ENGINE:
Virgin Bore 4.0 A4 Block
Splayed Mains
Arp studs
Melling High Volume Oil pump
Cola Crank 2 Key ways
Eagle H-beam Rods
Ross Pistons (Comp is around 8.8:1)
Hellfire Rings
Piston Custom Flycut for Twisted Wedge and Inline Heads
7 quart Deep Oil Pan
Trick Flow Track Heat Heads/Dual Valve Spring
Trick Flow Hydraulic Roller Lifters
Trick Flow Push Rods
Trick Flow 1.7 Roller Rockers Stud Mount
Trick Flow Valve Covers With -12 Males Welded To -12 an lines ran to oil moroso catch cans W/breathers
F303 Cam
Romac Balancer
Trick Flow Box series Black Upper and Lower Intake.
BBK 70 mm Power Plus TB
Edelbrock Water pump
Afco Aluminum Radiator
Black Magic Extreme Fan (Temp Controlled with the FAST XFI)
3g alternator
Red Top Optima Battery (Located behind Bulkhead in Hatch) Battery cut off in Tail Light.
New Starter
Accel Coil
Stock Distributor With black MSD cap
MSD 6AL
TURBO:
Custom Profile Racecraft Turbo Kit
Precision 78 HPSH T4 Flange .96 AR
-4 Steel braided oil fed
air to air intercooler
2.5 inch cold piping Powder coated black entering engine bay.
1 5/8 primaries
2 inch hotside
3 inch DP
38 mm wastegate
4 inch Intake With K&N in fender
Engine Management:
Fast XFI ECU w/O2
Fast XFI internal Logging option
Fast Fuel injector Harness
Fast Ford TFI-ignition Adaptor Harness
Ford F.A.S.T. 3 bar Sensor Kit
Fast IAC Sensor
Fast IAC Adapter Housing
FUEL:
5 Gallon Fuel Cell W/foam
-12 feed to Weld On filter to
DB-2025A Weld On Fuel Pump
-8 Steel Braided Fuel Line Feed
BBRC powdercoated black Y-block
BBRC powder coated black Fuel Rails
-6 Steel Braided Return
-6 Steel Braided Vent
Aeromotive FPR
80lb inj
TRANS/DRIVETRAIN:
Fresh EFI Renegade Specd C4
JW Bell
Scattershield
Billet input shaft
New Planetary Gears
3800 Stall Converter From Lenny @UCC
Reverse manual Valve body
Trans Brake
Turbo Action Cheetah Shifter
Holley Line Lock on handle "THUMB"
TCI Flex Plate
Aluminum Driveshaft
3.27 Gears
Explorer Posi 31 Spline
31 Spline Strange SS street axles w/CCLIP ELIM
LPW Girdle
Chassis:
Wolf 10 pt Chromoly Cage
Wolf Thru floor Subframes
Wolf Minitub
Reinforced Torque boxes (Wolf Plates)
Wolf Bulkhead
Suspension/Steering/Brakes:
Flaming River Manual Rack
UPR Bump Steer Kit
Bob Kurgans Old Solid Motor Mounts...lol
Team Z K member
Team Z A Arms
Team Z Double Adjustable Upper Control Arms
Team Z Single adjustable Lower Control Arms
Team Z anti roll bar
Adjustable Strange Shocks "Stock Location" With Minitub "Custom Bracket"
QA1 Springs in stock location With Wolf Adjuster Nut
Adjustable Strange Coil overs Front
Caster Camber Plates Team Z or UPR?? Can't remember lol
Aerospace Front Drag Brakes With coated steel braided lines.
Drums in rear
GUAGES:
Autometer Tachometer Shift light
Auto meter BOOST Guage
Auto Meter FUEL PSI Guage
Auto Meter Mechanical Oil Psi With -4 steel braided line
Auto Meter Water Temp Guage
AEM TRU BOOST CONTROLLER
Old 04-30-2012, 06:35 PM
sammy469's Avatar
bump...
