01' SS Cammed, Stalled, 6.0l, LS3 Heads UMI suspension
Year: 2001
Make: Chevrolet
Model: Camaro
Price: $13500
Mileage: 54300
Private or Dealer Listing: Private Listing
Location (State): AZ
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Engine
The block has 50k miles on it. The heads are ported with PRC EHT .675" springs. It has a TSP 231/236 .641''/.615'' LS3 cam. It has a stock LS3 intake with a edelbrock 90mm tb. The headers are TSP 17/8" ceramic coated headers with a bassani x pipe and spintech mufflers. It also has ls7 lifters and hardened pushrods. The oil pump is a new ls6 unit.
Trans/Rear
Built by Top Gear Motorsports in Mesa Az. Has a beast sun shell with all the goodies. The converter is a Edge unit and is a 4k stall. Trans has 500 miles on it since rebuild. The rear is the stock 10bolt with 3.73 gears.
Chassis/Suspension
Car has a UMI K member with tubular upper and lower control arms with adjustable QA1 coilovers and UMI solid motor mounts. The car also has UMI 3point sub frame connectors and a UMI tunnel mount torque arm. The Panhard bar is a adjustable UMI unit and the rear shocks are adjustable comp engineering.
Wheels/Tires
Wheels are Summit Drag thrust wheels with Mickey Thompson ET Street radials in 275/60/15 in the rear and 26/7/15 MT radial front runners.
Fuel
Racetronix pump with hotwire kit and stock ls1 injectors for now.
Im probly forgetting other stuff so feel free to ask. I owe a little bit of money on this car still so the title will come from the lender. Im asking 13,500 for the car and Im not looking for any trades.
