1998 Trans Am lq46.0 swapped
First of all I'm posting this from my phone so I can't figure out how to upload pictures if you interested text me for photos at 8503902816.
For Sale is my 1998 Trans am with a LQ4 6.0 swap. The build sheet is as follows..
The engine, transmission, & tires have about 1,500 miles on them
2002 LQ4 6.0, that has been rebuilt Has maybe 1,500 miles on it. (The actual car has 4 miles on it) Rings, bearings, all GM gaskets, seals, and sensor's have been replaced.
Block was honed. Rings have been gapped for a FI or nitrous setup.
Chrome moly piston rings.
LS2 timing chain
LS6 oil pump
Katech rod bolts on the later model dimple rods
LS6 cam (02 up model)
317 heads w/ 5 angle valve job
LS6 springs, retainers, keepers
ARP head studs
CV .080 chrome moly pushrods
LS6 intake
FAST fuel rails
stock throttle body w mods
1 3/4 headers (bought from a friend, don't know what brand)
3" X pipe into 3" Classic Chambered Powerstick mufflers (true dual exhaust)
tail pipes ran under the rear end, all exhaust uses stainless band clamps for easy removal
Racetronix 255 pump w/ ground kit
Has a speed density tune by JonCR96Z.
Has cold air conditioning
4L60E with all the good parts in it. LS1 Bob built it for me.
5 pinion planetaries
hardened input & tail shafts
HD thicker sunshell
HD sprag
Trans Go shift kit
Billet servo
It would be considered a Level 3 or 4 transmission
3200 Precision Vigilante stall
HD transmission cooler
7.5 rear with 3:42 posi
Polyurethane control arms & an adjustable panhard bar that I make myself.
Bilstein shocks all the way around
Drilled rotors on the front (not sure what brand they are)
SJM ABS delete & line lock kit (I haven't wired the line lock up yet)
Continental 245/40/17 tires & Speedline wheels
Had the car dynoed at Aquadale Speed Shop. Car made 398hp@5900 & 400trq@4650. The car runs great.
I bought this car from a fellow brother here on ls1tech and the car is aweosme. Sadly I may be moving to key west here in a few months and can't take 2 cars with me. I would prefer someone who will respect the car buy it from this site not Craigslist. This is the only place the car will be posted. Please feel free to text me with questions or for pictures. 8503902816
Asking $10,500 OBO
LS2 timing chain
LS6 oil pump
ARP head studs
LS6 intake
FAST fuel rails
HD thicker sunshell
HD sprag
Trans Go shift kit
Billet servo
Asking $10,500 OBO
