WS6 with under 35k miles, track ready, and $30k in mods
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $15999
Mileage: 34026
Private or Dealer Listing: Private Listing
Location (State): OH
Color: Brown
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Pewter Metallic, 2001 Pontiac Trans Am Ws6. 34,XXX miles
Upgrades:
From WS6 Store
Clear air lid, SLP Smooth Bellow, K&N Filter
SLP High Flow Mass Air Flow (currently out of the car due to a SD tune)
SLP Strut tower Brace
Hypertech 180 degree thermostat
QTP Electronic Cutout
QTP Long Tube Headers
24" Oxygen Sensor Extensions
12" Oxygen Sensor Extensions
Fast/Nick Williams 90mm combo
KYB Adjustable AGX Front Shocks
KYB Adjustable AGX Rear Shocks
Brembo Front Slotted Rotors
Brembo Rear Slotted Rotors
Comp Cams RPM Valve upgrade kit - push rods,retainers
Casper O2 Sensor Simulators
UMI performance Lower control arms & panhard bar single adjustable
Patriot Gold dual valve springs
SLP Heavy Duty Oil Pump/Timing Chain Package
Spohn Drive Shaft Safety Loop
Racetronix Fuel System
Jegs
Flowmaster 3inlet 3 outlet 80 series muffler
Eibach Pro Kit Springs (front only)
BMR Super transmission cooler
AFR 205cc Heads 66cc combustion chambers 85cc exhaust ports
Com cams custom grind cam shaft (see below for details)
Mickey Thompson ET Street 275/40-17
Nitrous Activation Switch
Holley Fuel Pump Safety Switch
Nos Digital Progressive Controller
Triple Guage Pod housing
N2O bottle pressure gauge,
A/F wideband sensor,
Fuel pressure gauge
G-Force 5 point harness
Billingsley Racing
Reluctor Rings (4 Channel)
Aluminum Support Cover
Super Strength Posi Unit (4 Channel)
Backing Plates (4 Channel)
Strange 12-Bolt RearEnd Assembly (wheen sensor has been recently removed)
33 Spline Axles
note: abs sensor has been removed
Lasota Racing
Custom 3'' cat back made by Rob Lasota (y-pipe)
Nitro Daves Nitrous Outlet
2' 3an-4an blue sho hose (to handle up to a 250 shot)
Stand Alone Fuel System
purge kit, routed to spray from the ram air nostrils.
Rossler Transmission's
Terminator 3 transmission rebuild with deeper tranny pan and Trans brake.
Summit Racing
#42 SVO Fuel Injectors
Umi Performance
3-Point Subframe Connectors
Full Length Chrome Moly Adjustable Torque Arm
Torque Arm Relocation Kit
Ls1tech
NX wet kit with extras - (window switch/3000-7000 pills/bottle heater/switch panel/billet bottle holder/wot switch)
Wolf 5 point roll cage
Yank Performance
Yank 3600 Torque converter
Texas Speed
233/239 112lsa camshaft
603rwhp(447 on motor)/ 710 Foot pounds torque
*****Pics http://animoto.com/play/mVd8mEQyK6eA1Jd3CNv0Bw
Best time of 10.7 @128. Never really pushed it to its full potential.
I'll take some pics of the paint imperfections here in a sec. For anyone looking to make a super fast car this is a great car to start with.
Bad little kid damage
Also, the plastic loop for the seatbelts has cracked (the one on the side of the seat). Garaged for all its life, non smoker, runs fine, starts right up, ac and stereo work great. After having it for 12 years its time to move on.
