2002 Camaro Drag Roller 10k Original Miles - 12 Bolt - Cage - Full suspension
Year: 2002
Make: Chevrolet
Model: Camaro
Price: $9800
Mileage: 10800
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Black
2002 Z28 with 10k original miles. Still smells like new inside and doors close like a brand new car. Car needs a motor and trans and is strip ready. Ran very consistent 9.80s with previous LS7 / TH400. Suspension is dialed in and car launches straight. This car was not hacked up at all, bump stops were removed but wheel well and quarter lips are still factory.
- BMR Tubular K-member with manual pinto rack
- BMR Tubular uppers
- BMR Tubular lowers
- Spohn Extreme body mount torque arm
- Weld-in tubular subframe connectors
- Moser 12 bolt with 4.30 gears and lightweight spool
- Wheelie bars (trunk pan has very clean cutouts to clear the bars that look like they came from the factory that way)
- MRC billet anti rollbar
- Tubular adjustable panhard bar
- Tubular adjustable lowers
- Strange brakes all around
- Strange coil overs up front and strange shocks on the rear
- ABS delete with adjustable prop valve
- B&M ratchet shifter with line lock / transbrake button
- Line lock
- Progressive N2O controller in the dash
- 10-point cage with swingouts
- 5" tach with shiftlight
- AC firewall delete panel
- Relocated battery with trunk switch
- Billet catch can
- Aftermarket lid with ram air
- Weld Alumastars with 28.0/10.5-15 Hoosier slicks and 27.5/4.5-15 M/T ET front runners (also have an extra set of 6" wide Alumastars for the front to run a wider tire)
- VFN Cowl Hood
- Grillcraft Billet grill
- Tenzo Racing seats with G-Force 5-point harnesses
- Factory LS1 / T56 wiring harness and PCM
I'm sure there is more that I forgot to mention. Also have Dynatech long tube headers and complete TSP true dual exhaust that was on the car along with a complete 4" catback with Spintech muffler.
There is a ton of money in this setup and if you're looking to hit the track all the hard work is down and this roller is ready to go. Looking to get $9,800 as it sits.
Any questions feel free to call or text.
336.339.6867
Rick
