2005 Pontiac GTO (Backhalfed, Roll Cage, Solid axle w/Ford 9")
Year: 2005
Make: Pontiac
Model: GTO
Price: $19000
Mileage: 53128
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Yellow
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
https://www.dropbox.com/sh/n9xcp64be...VCerQBH-a?dl=0
ENGINE:
370c.i.Iron Block -Forged piston and rods, Balanced
CNC ported Ls3 heads
Custom cam
Ls3 intake
Fast rails and 60pph injectors
90mm t.b.
JDA Stainless 1 3/4" longtubes
(Sold) F1a Procharger-8 rib pulleys and gto intercooler. piping system and crank case vac system.
Stock ECM with HPTuners S.D. tune- base file (Conservative 93octane)
Transmission:
Built 4l80 with manual valve body, 3500-3800 stall, and ratchet shifter
Drive shaft:
Steel 1 pc. with heavy duty U joints
Rear end:
Ford 9" solid axle with Torque arm, chassis mounted
Mini tubbed
Coil-over adjustable shocks front and rear
Body:
Exterior mostly stock with Weld drag light wheels
Interior:
Stock power front seats
5 point harness
altered counsel for auto shifter
rear seat DELETE
additional switches for optional equipment
Fuel tank :
Big in-tank pump. stock location.
Will sell the roller wo/transmission for $10000
Engine for $7000 and ECM
Trans for $3000 w/ converter and cooler
