1998 Camaro SS New motor,rebuilt tranny,12 bolt
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $9500
Mileage: 105000
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Brand New motor - less than 50 miles
Automatic Transmission was rebuild less than 2,000 miles ago.
Rear end is a 12 bolt Moser with 3.73 gears - less than 15,000 miles
QAI fully adjustable shocks and springs
UMI subframe connectors
BMR torque arm
BMR rear lower control arms
BMR pan hard bar
BMR front and rear sway bars
Baer Eradispeed drill/slotted rotors and pads
18x9.5 Z06 wheels
SLP longtube headers
SLP loud mouth exhaust
Odometer has 105,000 miles
$9,500
Call (636)-448-6018
Apoligies for so many questions.Did you assemble short block with 98LS1 heads from 98SS for sale?Valve job or lapped in?New or used springs?Head p/n? Who was supplier of "rebuilt tranny"? 12 bolt builder? You build or shop install of 12 bolt.Pinion snubber? Type of 3rd member configuration? Thanks in advance! Closer to K.S.MO. or St.Louis,MO.? I am in Wagoner,OK.,reason for so many questions.Apoligies for so many questions,its sounds near my needs.
I have owne the car for over 11 years and had 86,000miles when I bougth it. It has been cover in the garage since Ive owned. Only 19,000 in 11 years. The motor is a brand new 04 gto ls1 long block $3200. The motor was purchased through Scroggin Dicky parts center. Has an ls6 intake manifold. The transmission is an 02 4l60e that had low miles
I had the transmission rebuilt with heavier duty parts and a shift kit. There is a trans cooler also. The moser rear end was bougth new. 35 spline axles. 3.73 gears.
My dad is a ASE certified mechanic. He has a lift is his garage. He did all the work to the car. The motor in the car has doesn't even have 50 miles.
If you have anymore questions call me at 636-448-6018.
You say the motor is brand new, but then you also say it's from an 04' GTO (10 years old). Does that mean the motor was rebuilt 50 miles ago and if so how many miles did it have when it came out of the GTO?
The motor is new. It was bought as a new ls1 long block for an 04 gto. So it came with a gto oil pan. The long block was $3200. I would have put a ln ls6 in but there are no more ls6 long blocks anymore.
Still have the car?
Interested in your car- would you take a 95 z28 roller, new paint, tires, nice interior part trade? cash rest? I'm thinking at least $2500 for mine
1998 Camaro SS
BMR torque arm
BMR pan hard bar
18x9.5 Z06 wheels
$9,500
Call (636)-448-6018
BMR torque arm
BMR pan hard bar
18x9.5 Z06 wheels
$9,500
Call (636)-448-6018
I didn't keep the reciepts. At the time I bought everything I didn't think I was going to sell the car.
If your actually interested call. This car is a lot nicer than a lot of cars on here asking the same amount. New motor, recent rebuilt Trans, and 12 bolt. Headers, catnack, qa1 coilovers fully adjustable, front and rear bmr sway bars, rear pan hard bar, rear lower control arms, torque arm, umi sub frame connectors.
