2005 GTO - full suspension and bolt ons
Year: 2005
Make: Pontiac
Model: GTO
Price: $13500
Mileage: 104211
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Yellow
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Drivetrain mods:
Lingenfelter CAI
Ported stock LS2 intake manifold
Firecore 50 wires
Kooks long tubes and catted mids
Corsa touring exhaust (left tip is bent/scraped)
YJ powdercoated oil catch can
Diablo handheld tuner with SLP tunes
MGW-P shifter
DSS aluminum driveshaft
Harrop diff cover (RGO fluid)
GForce level 1 anti-wheelhop axles
Monster level 2 clutch (nearing end of life)
Suspension mods:
Pedders radius arm bushings and upper strut mounts
Pedders front and rear sway bars
Roadsafe heavy duty bushless endlinks
Whiteline rear control arm quad eccentric bushings
Pedders subframe bushings
Koni adjustable shocks and lovell springs
Other mods:
JHP guage pod (bar instead of psi with red needles)
Lots of sound deadening as you can see in the thread above
Aftermarket headlights with LED halo and 5k HID in low beams
Tinted front side markers
06 tails
Drag 18x8.5 et40 wheels with 255/35/18 RE-11 tires
DBA 4000 6x6 rotors and Hawk ceramic pads
Super Blue fluid for brakes and clutch with speed bleeders on all calipers
Tick speed bleeder for slave cylinder
Tick master cylinder
All new belts and coolant flush at 75k
Clarion DVD/Nav head unit with steering wheel controls and parking brake bypass
Programmed gauge cluster and shift light (i can make it whatever you want as well as change message and startup logo)
YJ "GTO" door sills (discontinued item)
