Year: 2000
Make: Pontiac
Model: Trans Am
Price: $5000
Mileage: 103000
Private or Dealer Listing: Private Listing
Location (State): FL
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
First the car is not running. The engine locked up on me a few weeks back. I don't have the time to work on it. I believe it could either be a cracked rod or a spun bearing. I recently put new ported 243 heads on it. Other than that the car body is great. Full suspension tons of mods if you even wanted to swap out and put a lsx in it. T56 tranny shifts perfect. Selling really cheap $5000 I'm not going lower than that. Google or eBay all the parts I have on the car. Below are the listed mods. Tan leather interior no dash cracks. Windows, radio everything works. Video of it when it was running.
Engine/Exhaust: 243 Ported and milled to .30 Texas Speed MS3 Comp Cam (238/242 .608.609 112LSA) Comp Magnum Pushrods Comp dual springs valve springs FAST 90MM Intake Manifold FAST Fuel rails 46lbs fuel injectors Nick Williams Forged 90MM Throttle Body SLP Air lid/K&N filter 180* Thermostat Pacesetter Coated Headers Off road Y Pipe 3" Corsa Exhaust NGK TR6 Plugs/10mm OML wires Suspension/Driveline: KYB AGX Adjustable Shocks SLP Diamond sub frame connectors SLP Driveshaft loop Heavy Duty panhard bar BMR Torque arm Heavy Duty Front and rear sway bars Heavy Duty rear control arms Tower brace Brake line lock Short throw shifter Mcleod stage 2 dual disk clutch TSP chromoly driveshaft (good for 1200+HP) Moser 12-bolt rear with 4:11 Gearset Drilled and slotted rotors front and rear Tick master cylinder C6 Corvette wheels staggered 17' front 275 and 18' In the rear 295
