1993 RX7 LSx/t56 Swapped
Year: 1993
Make: Mazda
Model: RX-7
Price: $20000
Mileage: 120000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
Make/Model: Mazda RX7 Touring
Miles:120,xxx on shell
Color: Red exterior/tan interior
Contact Chris via PM or Text (248) 240 – 6247
Price: $20,000 OBO
Overview:
Up for sale is a clean 1993 RX7 with a L59 5.3 LSx swap. Car runs awesome with a solid tune by Walsh Motorsports, dyno sheet is available. The car is currently set up to run TTS/ST2 class at Waterford hills. The car is in the middle of being a full blown race car, drift car or a bad *** street car. It will come with all stock interior components and can be put back to street look. No rust! OK now on to the happy:
Exterior:
Set up with 99 stock look at the moment, paint has been touched up and looks great for a 21 year old car.
12 stock FD wheels, 8 with Toyo RA1 tires
Interior:
-Currently set up to run in the aforementioned class. Only interior in the car is has half door panels, has rear storage buckets. Other misc. trim that fit around the cage. Diamond plate false floors on drivers and pass side. More panels are installed since these photos/video were taken.
-Recaro RZ seats and harnesses.
-Weight reduction (panels, carpet radio, etc.)
- Autometer water temp, AEM Wide Band, Stock RX7 cluster works
- FIA/NASA/SCCA legal full cage that is integrated to the rear suspension. All is painted and looks great.
-Fire system
-Momo wheel with quick release
Suspension:
-Tein Mono Flex Coil overs
-SS brake lines, Hawk pads, Centric blanks
-All bushings redone in Polyurethane
Drivetrain:
-RX7 3:90 Rear end, External Diff Cooler, Drive Shaft Shop drive shaft
-2004 L59 5.3L LS motor
LS6 Cam
LS6 Valve train
LS6 Intake
BBK 80MM Throttle Body
Stainless works (Hinson) Headers and Y-pipe, Apexi Catback
MSD Wires
Oil Pan Baffle
Hinson Intake
Wally 255 Pump
LS6 Injectors/Rails
-T-56 6-speed
Monster Clutch kit
Stainless line
New master/slave cylinders
-Hinson Cooling Set Up
-Hinson Engine Harness
-Hinson Swap Mount Kit
-Painless 8 Circuit System
Old RX7 you tube video
