1999 bmw 5 series lsx t56 swapped
Year: 2017
Make: BMW
Model: 5-Series
Price: $15000
Mileage: 155000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
1999 540i 6 speed car
No accidents very clean above average body and no rust
Modified bmwman528e mounts to accept ac
All fab work and exhaust work is professional
This car only needs a high pressure ac switch wired in for fully functional ac
All brand new ac
F Body ac compressor
F Body ac condesnsor
Custom lines
Brand new belts and pulleys
LS1 Shortblock 80k miles
-Modified GTO Oil Pan Powdercoated
-LS6 243 Heads
-Patriot Double Valve Springs w/ Ti Retainers
-Ported LS6 Oil Pump
-Double Roller Timing Chain
-LS7 Lifters
-LS2 Trays
-Custom Cam .612 In .618 Ex. 232/234 Duration 112 LSA
-LS6 Intake Intake and Injectors
-LS6 Valley Pan and PVC
-F Body Radiator and Fans
-F Body Accessory Drive
-85mm MAF
-Custom K&N Intake Setup
-Custom High Temp Power Steering Lines
-New OEM Rubber Engine Mounts
AMW catch can
Suspension:
-Low Mile OEM Shocks and Springs
-M5 Front Sway Bar
-Dinan Rear Sway Bar
-Powerflex Control Arm Bushings
Brakes:
-New Rotors
-Hawk Pads
-Stainless Lines
Transmission:
-Rebuilt T-56 Stage 2 by Donnato Transmissions
-New Bronze Fork Pads
-Carbon Synchronizers
-Brand New Input Shaft
-Brand 3,5,6 Gears
-LS7 Clutch and Flywheel Shimmed 0.125"
-Tick Speed Bleeder
-New F Body Trans Mount
- New pro 5.0 shifter with Modified handle to accept Hurst oem ****
Rear End:
-E34 M5 3.91 LSD Rebuilt
-E39 M5 Diff Cover
-Custom Diff Bracket
-Redline Full Synthetic Fluid
-Custom Rebuilt OEM style 2 Peice Driveshaft
zero miles
Exhaust:
-1 3/4" Mid Length Headers Ceramic Coated
-3" Collectors with V-Band Clamps
-New 02 Sensors
-Full Dual 3" X Pipe
-M80 Pypes Mufflers
-All exhaust coated
The factory speedometer, tachometer, and OBD2 all work. LS1 Computer was tuned by Frost. Staggered Style 32's have brand new rubber. Rear's have 275 Nitto Drag Radials. Car runs and drives as if it were stock. No abnormal harshness or vibration! This car is quick breaks necks anywhere it goes. No expense was spared when building this car. The exhaust sounds absolutely amazing. Never been to the track but should be right at low 12's high 11's. This car is loud but sounds really good. I've put 500 miles on it last few weeks daily driving it . Never gets above 200 degrees even in 90 degree heat sitting in the woodward dream cruise for hours. Every option besides the window and fog lights work including the cup holders. Zero leaks very clean underneath.
Issues
-Rear Pass Window Broke needs a regulator
-Fog Lights Don't Work
-Tachometer is off needs to be adjusted with hp tuners maybe be done before sale
-Ac needs a high pressure switch and refrigerate added. But everything ac related is installed and new
<a href="http://s955.photobucket.com/user/081000rrcbr/media/20150902_123432_zpskohp4qxr.jpg.html" target="_blank"><img src="http://i955.photobucket.com/albums/ae36/081000rrcbr/20150902_123432_zpskohp4qxr.jpg" border="0" alt=" photo 20150902_123432_zpskohp4qxr.jpg"/></a>
