2001 T/A cammed/th400/nitrous/darkstars etc....
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $9000
Mileage: 108000
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Black
Transmission: Automatic
SLP lid
SLP 85mm MAF
Smooth bellows
K&N filter
1 7/8" longtubes
TSP ORY into 3" dynomax race bullet dumped y pipe needs welded together.
MS3 cam(237/242 .603/.609 112lsa +1(less than 4000 miles on cam swap)
PRC .650 springs
7.400 hardened pushrods
Melling high presseure oil pump
N-motion single roller timing chain
Stock 241 heads
LS6 intake
racetronic 255lph e85 compatible fuel pump+hotwire brand new 50 miles
Spot on tune by JUSTUNE 27* timing and a/f 12.8
nitrous setup
n.o.s. brand fuel and nitrous solenoids less than a full bottle ran through
nitrous outlet brand x purge kit
lnc-2000
msd digital window switch
full bottle
jetting to 150hp
homemade switch panel
FTI lvl 3 th400 good to 800hp *200 miles w/reciepts
FTI hard hit 4000 stall *200 miles w/reciepts
Tranny cooler
fmvb
arp flywheel bolts
bmr adj torque arm relocation th400 transmission mount
energy poly mount
3" steel driveshaft with 1340 u-joints
SLP strut tower brace
Removed front sway bar
Lowered 2"
BMR lca's
BMR adj. panhard bar
Stock 10 bolt w/ 3.23
RACESTAR DARKSTARS 15X10 AND 15X3.5 200 MILES
MICKEY THOMPSON ET STREETS 295/55/15 200 MILES
FOSGATE PUNCH speakers throughout
1200 watt amp
2 12" subs
Sony cd
Dual a-pillar pod
35% tint all around
Lo-jack equipped
Vht'd side markers
Removed molding
Wire tuck
leather ........ the car has brand new darkstars 15x10 and 15x3.5 and brand new mickey thompson et streets 295/55/15 300 miles on them no burnouts. the car isnt perfect.needs y pipe welded up. has some scratches and a door ding or two. hood has few dings but it needs a ram air hood anyway!someone stole the trans a badge on the right door and peeled paint off with it. interior needs a good detail and carpet cleaned. few ac vents broke.needs new window motors and driver headlight motor. Could use new hood and hatch struts also.the y pipe needs welded up. cam,pushrods,oil pump and valve springs got 8k on them. th400 and stall got 300 miles if that. i got $3600 just in the transmission swap i did last winter. all paperwork comes with it. nitrous kit and lnc2000 and msd window switch is brand new also.
im not on here much at all. for a response text me at 816-872-2180 and im kansas city missouri
