1991 S10, LQ9, Built TH400, Plate Kit, NASTY!
Year: 1991
Make: Chevrolet
Model: S-10
Price: $7500
Mileage: 100000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Blue
Transmission: Automatic
Drivetrain: Rear Wheel Drive
2005 6.0 LQ9 (Rings gapes .28/.26, FM Main/Rod Bearings, Floating LQ9 Rods, Coated LS2 Pistons, standard bore)
Custom BTR Nitrous Cam
ARP Rod Bolts
BTR Dual Spring Kit
5.3 Cylinder Heads (Deburred)
LS7 Lifters
PE Head Studs
LS9 Head Gaskets
Flex Fuel Injectors
NGK BR7EF Plugs
NOS 78mm Plate (Nitrous Outlet Solenoids)
Custom LSx Unlimited Fabbed Harness (PCM mounted in Cab, harness is hidden)
LSx Unlimited Nitrous Retard Box
LSx Unlimited Custom Tune (Speed Density)
SFI Removeable Bellhousing TH400 (Less than 200 miles, Red Clutches, Kolene Steels, 36 Element Sprag, 4l80 Drum, TCI Manual ValveBody)
Dual Plate 3800 Converter
B&M QuickShifter
Twin Bosch 044 Fuel Pumps
20 Gallon Aluminum Cell
Ford 8.8 Rearend 3.73 Gears
McKnasty Anti-Twist Traction Bars
18" RaceStars up Front
15x10 RaceStars out back
275/60 Pro Tires
I really hate to sale this monster but I'm concentrating on my turbo truck at this time. You can drive this truck anywhere, runs amazing! I do not have any dyno numbers or track times, I strictly grudge race with this truck however it is a pretty fresh build and have only ran 1 bottle thru the motor on a 200 hit. I have a pretty good idea of what it runs and will disclose that info to the buyer. Very fast truck on not recommended for a first time race unit, its nasty. This is not a show truck by any means, it was built for business but is a very strait truck.
Price very fair at $7500.
Not looking for trades but may consider a nice daily, etc.
Located in Alvarado, Tx
I work for LSx Unlimited and we built this truck on the side.
817-565-7594
