FS/FT 2015 STi 500hp to the tires
Year: 2015
Make: Subaru
Model: WRX STI
Price: $39500
Mileage: 18187
Private or Dealer Listing: Private Listing
Location (State): IN
Color: Silver
Transmission: Manual
Drivetrain: 4WD & AWD
If you guys don't understand what 500 horsepower in an all wheel drive car is, I will compare it to roughly 700 to 750 horsepower to the tire rear wheel drive car.
Every mod on this car is only at about 5K miles with receipts for everything done. The car has all mod except sunroof from factory!! Including Navigation.
Can is still under bumper to bumper except the motor or course. APM out of illinois has that part covered. APM did the motor and mods to the car.
Bottom End:
New Case Halves
CP Forged Pistons
Manley I-Beam Turbo Tuff Rods
King Main & Rod Bearings
ARP Head Studs
APM 12mm Hi-Flow Oil Pump
Killer B Oil Pan
Killer B Oil Pickup
Killer B Oil Pan Baffle Windage Tray
Fumoto Drain Valve
Heads:
Mutli-Angle Valve Job
Kelford 220-B Cams
SuperTech Intake & Exhaust Valves
SuperTech Dual Valve Spring Kit
Bolt Ons:
ATP Turbo GTX3076R Externally Gated Turbo
Tial MV-R Wastegate 44mm
Tial QR BOV
Grimmspeed Black TMIC w/ Grimmspeed Y-Pipe Kit
Perrin 3" Turbo Inlet
AEM Cold Air Intake
Tomei ELH (Heat Wrapped)
Nameless Catless Downpipe (Heat Wrapped)
Invidia Dual N1 Catback w/ Titanium Tips
IAG AOS
Grimmspeed Boost Control Solenoid
Go Fast Bits Lightweight Pulley Kit
Flat 4 Motorsports 6AN AVCS Line Kit
Torque Solutions Engine, Trans, & Pitch Stop Mounts
APM TGV Deletes
APM Air Pump Delete
Koyorad Aluminum Radiator
Samco Black Radiator Hose Kit
Fuel System:
ID1300’s w/ PnP Adaptors
IAG V2 Fuel Rails, Lines & AEM FPR
DW65c Fuel Pump
Engine Dress Up:
Perrin Red Belt Cover
Perrin Red Radiator Shroud Cover
Perrin Red Boost Solenoid Cover
Perrin Black Upper Radiator Stays
IAG Aluminum Black Dipstick
IAG Aluminum Black Power Steering Cap
IAG Aluminum Black Master Cylinder Cap
IAG Aluminum V2 Black Billet Oil Cap
IAG Aluminum V2 Black Windshield Washer Fluid Cap
IAG Aluminum V2 Black Coolant Cap
JDM Look-a-Like Radiator Cap Stickers
Exterior Mods:
JDM Grill w/ no STi Logo
JDM DRL Fog Bezels enabled as DRLs
Nokya 2500K HB3 Bulbs w/ Disabled DRL's
LED Fog Light Bulbs
Lamin-X Fog Overlays
LED Turn Signals (Front & Rear)
LED Marker Lights
LED Reverse Lights
LED All Interior Lights & License Plate Lights
JDM Rear Fog Light w/ LED 7443 Bulb & Socket (Used as Parking Light/Third Brake Light w/ Disabled Factory Third Brake Light w/ BrakeXP Module)
Windows Tinted 20%
JDM Aero Splash Guard Kit
TapTurn Module
Smoked Tail Light Overlays
Hella Supertone Horn Kit w/Harness and Bracket
Carbon Fiber Front License Plate Delete
Carbon Fiber SPT Trunk Trim
Carbon Fiber License Plate Bracket
Interior Mods:
JCS Triple Gauge Pillar Pod
Defi Red Racer Gauge w/ White Needle - Boost
Defi Red Racer Gauge w/ White Needle - Oil Pressure
Defi Red Racer Gauge w/ White Needle - Oil Temperature
SMY 2-Gauge Cluster Pod
Zeitronix Wideband Gauge
JDM Dual Console
Carbon Fiber E-Brake Handle w/ Chrome Button
WeatherTech Floor Mats
Acrylic Conceptions Cup Holder Inserts
Anarchy Motive Goliath Shift **** - Rough Red
Carbon Fiber Center A/C Trim Cover
JDM Boost Gauge Panel Cover
Wheels & Tires:
Wedsport SA-72R 18x9.5 et45
Bridgestone Potenza S-04 Pole Position 265/35r18
Muteki Burned Blue Lug Nuts
Drivetrain & Braking:
ACT HDSS Clutch
Perrin Black Master Cylinder Brace
Kartboy Shifter Bushing Kit
I HAVE SEVERAL MORE PICS OF THE CAR. IF YOU WOULD LIKE TO SEE MORE JUST TEXT ME AND I CAN PROVIDE THEM. TEXT ME AT 317-710-4887.
Thanks for checking this ride out.
