Trans Am, 75k miles or less, M6, modded
I may be selling my car to my dad and buying a replacement for myself. I'm looking for a modded M6 TA with low-ish miles (sub-75k).
When I say modded, I am thinking bolt-ons and possibly cam. Upgraded rear end is a huge plus. Basically I'm trying to avoid as much of the cost of modding my own car which is nearly stock, and buying one that's already modded will achieve just that.
Looking to spend around $11,000 or less if possible. Post up what you've got.
My car is up for sale. (Not the car in my sig) Check it out:
https://ls1tech.com/forums/vehicles-...low-miles.html
48,000 miles on this mint condition white Trans Am. Heads & Cam Package (Around 440 HP at the wheels!) With good tires this car would be running the 1/4 mile in the 11's pretty easy. Feel free to email me with your name and number if you have more questions. chad@anytimefitness.com
$14,000 Firm. A great deal considering all the Mods and Parts that this car has.
*Dart Pro 1 LS1 205cc Heads, 2.02" Intake, 1.60" Exhaust
*Futral Motorsports Cam, FM14, 232/234, .599/.603, 112 LSA with a +4 advance
*Comp Cams Hi-Tech One Piece Chromeoly 7.425" Pushrods
*Chromoly piston rings
*Rebuilt T-56 Transmission Carbon Fiber Synchro Assembly Rebuild Kit (1-6)
1-2 & 3-4 Synchros were treated to Metal Enhancement (Shot Peen, Thermal Stabilization Cryogenic Processing and Metal surface enhancement polishing) done by Liberty Gears. This will greatly increase the overall strength and durability of the transmission components.
*Steel 3-4 Shift Fork with Bronze fork pads and Billet Steel Insert
*QTP 1 3/4" Long Tube Stainless Steel HVMC Race Headers
*LS6 Intake port matched to Dart Heads
*Delphi/Lucas #32lb Injectors
*QTP off Road Y-Pipe
*March Performance 25% Reduction Under drive Pulley
*Walbro 255L Fuel Pump
*LS6 Ported Oil Pump
*Comp High Energy Lifters
*Rocker Upgrade Kit
*LS2 Timing Chain
*ARP Rod Bolts
*Whisper Carbon Fiber Lid
*SLP 90mm Throttle Body
*BMR White Strut Tower Brace
*BMR Boxed Sub Frame connectors
*Pro 5.0 Shifter with Speed Inc Short Throw Stick
*Poly Motor and Trans Mount
*South Bend DXD Stage 3 CryoFreeze Clutch and Flywheel with upgraded Hydraulics
*PCV Delete, EGR Delete, Air System Delete
*Brand new Chrome C6 Motorsport wheels w/ Kuhmo 275/40/18 rear 245/45/18 front
*Rocker Upgrade Kit
*LS2 Timing Chain
*ARP Rod Bolts
