Western Members CA, AZ, NV, UT, CO, NM, HI
California Smog Question
Old 02-13-2009, 10:16 PM
Thick_Ryan's Avatar
Default California Smog Question
I'm finishing up a 5.3 Vortec swap into my Jeep CJ7. I'm swapping the LS1 intake for the Vortec intake. The engine is a 99 but flashed as an 02 so it will not require the EGR. When I take it to the referee, will he give me crap for the EGR block off? Also, if I cover over the EGR block off with resin and paint over it, would that disguise it enough to pass?
Old 02-13-2009, 10:29 PM
lowerthanyou00's Avatar
the ls1 fuel rail wont work with harness because of the bosch style injectors( different connectors), other than that i thought there was no cali referees or something anymore, i forgot what i heard. Sounds like a great swap tho
Old 02-13-2009, 10:43 PM
Thick_Ryan's Avatar
If I use the Vortec fuel rails with the LS1 intake, would that work? then the harness would hook right up.
Old 02-13-2009, 11:32 PM
the fuel rail mounting points are different, i could be wrong on the injectors just because i havent messed with the 5.3s but the 6.0s are def different, the only way to get around it is wire on the bosch connectors or moybe theres a way of moddin the vortec fuel rail, or putting an aftermarket fuel rail on
Old 02-13-2009, 11:39 PM
roughneck427's Avatar
i have a 02 truck intake with rails laying in my garage to get it pass smog then swap back to the car intake. Ebay has the bosch connectors set of 8 for like 24 bucks
Quick Reply: California Smog Question
