Western Members CA, AZ, NV, UT, CO, NM, HI
Help with choosing tires
Old 10-01-2009, 03:48 PM
bman49's Avatar
Default Help with choosing tires
ok so I'm keeping my ZR1 style SS wheels, but I need new tires for them. I want to put 275s on the front and 295s on the back, but I don't know if 295s will fit on the wheels. I believe the wheels are 17x9s. I'm thinking I want some Nitto 555s, but I don't know much about them. What do you guys recommend?
Old 10-01-2009, 03:55 PM
MJs1FastSS's Avatar
are you sure they're 9 or 9.5?
i have 9.5 and a 295 kdw g-force on my rear
295s would be pushing it IMO on a 9" rim i would go with 285 max
or run 275 all around so you could get the most out of your tires and rotate them ever so often...just an idea and be cheaper
Old 10-01-2009, 04:01 PM
hitmanws6's Avatar
285s bulge on those, i had them on my SS wheels for a bit. stick with 275s all the way around. i have 555Rs on the back of my bird. i would highly recommend the 555 for you or the BFG Super Sport. if you have the money, get GS D3s
Old 10-01-2009, 04:02 PM
01 ss vert's Avatar
x2!
I run 275/315 and sometimes wish it was just 275s so I could rotate em. Since 275/295 isn't a signicant difference, and all 4 wheels are the same size - keep the tires the same size too!
Lot more choices in 275s too.
I run the nitto 555 on the front and it's a 275. I like it a lot. I've had good luck with BFG KDWs too.
Old 10-01-2009, 05:08 PM
bman49's Avatar
I just measured the wheels to be sure what size they are and it turns out they're 17x9.5s. MJ do you find that the 295s help with traction, or are they not worth it? Also one more question. Should I just have a shop just mount the tires to the wheel, or should I have them mount the tires, put the wheels on my car, and balance the tires?
Old 10-01-2009, 07:12 PM
hitmanws6's Avatar
have them mount and balance the wheels
Old 10-01-2009, 09:19 PM
MJs1FastSS's Avatar
Yes, have them mount and balance the tires.
As far as traction goes...yeah i get very good traction a lot of tire in the rear to grab and hook. It really all depends on what brand and what your intentions are/what your looking to spend...? good street tires vs. mickey Dr's ...... if your going to play... then wont last long reguardless
Old 10-01-2009, 10:36 PM
lowerthanyou00's Avatar
just ordered a set of the new goodyear eagles, just came out with a 275 size apparently supposed to be better than the old ones, i got my bud to buy a set of 275s all the way around on his camaro, got alotta tread and seem to be impressive.
Quick Reply: Help with choosing tires
