P0332 Code...need some clarification
Ive already searched and cant seem to figure it out...so my car threw the P0332 code...so i changed both Knock Sensors and harness...about a day later it threw a code again...took it to pepboys to get it checked out and it was the same P0332 code but they told me it was my "O2 sensor Bank 2 sensor 1" which would be the front passenger one...I thought this code was only thrown when there was knock...does it also apply for bad O2 sensors?
P0332 Knock Sensor (KS) circuit high/low voltage
If you've already replaced your knock sensor harness, you need to trace the wiring on the harness side to the PCM for damage, corrosion, burns, or exposed areas. Check to make sure that the pins on both sides of the connector to the harness are clean.
