Western Members CA, AZ, NV, UT, CO, NM, HI
LS3 starter issue.
Old 05-16-2010, 05:11 PM
Agent13's Avatar
Default LS3 starter issue.
Hello all,
My LS3's starter is giving me some problems...
Here is a video of what it's doing.
http://www.youtube.com/watch?v=muRF123A0js
Here is a link to the starter that I purchased.
http://paceperformance.com/index.asp...&ProdID=265458
When I first swapped in the motor it cranked fine the first time and then it started doing this. I noticed the starter gear was not retracting so I installed a couple of washers and it cranked fine for a few weeks and started doing this again. Once again the starter gear is not retracting. I removed the washers today and reinstalled the starter and it started twice. Now it's doing the same thing again...
Anyone have an idea of what it could be? The starter is only a few weeks old.
Old 05-16-2010, 07:45 PM
XpEdItIoUs's Avatar
First thing I would do is test the battery, make sure that it has no dead cells and how many cca it puts out. Then I would test to see if you have enough voltage at the starter solenoid, a good engine/chassis ground, followed by a voltage drop test on both B+ to solenoid and B- to case ground sides of the starter if it all passes then I would suspect a bad starter. These test can be done within 1 hour instead of guessing and having people guess for you which could be costly and a waste of time.
Old 05-17-2010, 12:51 AM
TPI TERROR's Avatar
who did your harness? and relays set up?. does you harness have its own starter relay?
i would check the ground.
Old 05-17-2010, 01:07 AM
180ls1's Avatar
agreed witht he two posts about i get the feeling it is fine and wants to crank but it is not getting the juice it needs.
Old 05-20-2010, 07:25 PM
SUCK MY SS's Avatar
sounds like a mis aligned pinion gear on the starter motor... are you using oem starter bolts? stock flywheel/flexplate?
Quick Reply: LS3 starter issue.
