Western Members CA, AZ, NV, UT, CO, NM, HI
DTC code for solenoid in transmission. EZ fix??
Old 09-06-2011, 04:00 PM
chevystyle's Avatar
Default DTC code for solenoid in transmission. EZ fix??
A buddy @ work wants to buy this '97 V6 camaro for $1,600 and use it as a DD. He said that there's no code in the add, just says something about a DTC code for solenoid in transmission. Is that an EZ fix or not even worth the $1,600 for the car price?
Old 09-06-2011, 04:11 PM
ae13291's Avatar
should be on the valve body, you need to remove the pan and filter and replace tranny oil.
Old 09-06-2011, 04:13 PM
mannyman84's Avatar
Does he know the code? But a DTC like that can be caused by low fluid in the trans or a bad solenoid.
Old 09-06-2011, 04:15 PM
mannyman84's Avatar
Might not work if the trans has been slipping for a while not building pressure due to that solenoid. The clutches might of wasted down and will end up in trans failure. Mostlikly the best fix is to rebuild.
Old 09-06-2011, 04:16 PM
mannyman84's Avatar
Also make sure to flush the whole system. radiator and all.
Old 09-06-2011, 04:32 PM
94'BLKBRD's Avatar
Guessing this is the car..
http://inlandempire.craigslist.org/cto/2584044261.html
Quick Reply: DTC code for solenoid in transmission. EZ fix??
