Western Members CA, AZ, NV, UT, CO, NM, HI
"Reverse" lights ONLY! not working..??
Old 03-29-2012, 08:38 PM
09camarossls2's Avatar
Default "Reverse" lights ONLY! not working..??
Both reverse tail's dont work..
I check for any blown fuses on the fuse box inside and out.. and nothing
Then B 4 i bought new ones i check the current reverse bulbs on "both" sides of the tails by swaping them arround on the brake socket's.. and bulbs do function..
I check for power on the socket/wires and am NOT getting any power..
Now.. everything on the car seems to be working just fine turn signals,dome map lights,gauges,DLR, ECT..
EXCEPT for the reverse sockets/ligh bulbs
Sockets are really clean both.. even that wouldnt explain BOTH sides going out uuhhmmm....
Can it be my reverse switch by the tranny..??
I have a 99 camaro M6
Any1 had this problem or any good advice..?? Thanks!
Old 03-30-2012, 01:35 AM
mannyman84's Avatar
Could be the reverse switch. Or a cut wire
Old 03-30-2012, 12:35 PM
ROCNDAV's Avatar
Here's a schematic to help you out
Attached Thumbnails "Reverse" lights  ONLY!  not working..??-backuplights99camaro.jpg
Quick Reply: "Reverse" lights ONLY! not working..??
