AZ emissions questions
Okay so iv'e got a 1995 v6 camaro with a ls1 swap when I go to get it tested do I tell them i have a 2002 drivetrain from a camaro in it?
Will I pass if a deleted AIR?
Will I pass with no exhaust, ending at the Y?
Will I pass with an ORY?
Im eventually getting a g5x3, ms3, or similar cam. Will cams of this size pass emissions or is that dependent on the tune? If I would fail anyways it would be pointless to run cats then right?
Your car will still be considered a 95. So that means you will be sniffed.
You will be ok with the air as long as you have had it programed out. If not you will throw a coed and you will not pass.
If you dont have CATS you will not pass either.
I take it you have LTs. If so you will need a CATed Y pipe.
Sorry for all the bad news. Best of luck to you.
