whats it worth?
whats it worth?
just seeing what you guy's think its worth honestly!
99 c5 torch red black leather, 44,000 miles, exterior is a 9/10 interior is great minus one small crack on the plastic between the shifter and the traction control button, going to change that when i go with a double din.
408 cui
trickflow heads,
comp nitrous cam,
callaway honker
kooks 1 7/8s, 3x 3 x pipe, b&b triflow catback,
ported 90mm intake, ported 90 throttle body
yank pt 3400 converter
rpm level 6 trans best of everything, dte brace
rpm level 3 diff w/ quaife 3.90 gears, also included are 3.42's all heavy duty shafts etc.
dedicated fuel system, battery relocate to the rear,
nitrous daves direct port system, 4 solenoid setup
custom switch panel, in ash tray
ccw drag pack, m/t et streets 4 passes,
skinnies in the front 4 passes as well
nitrous has never been used,
blackout kit on taillights, reverse lights, front corners,
car has a alpine cd head unit, alpine speakers in all the doors, alpine v power amp for those,
z06 syle screens in the fogs, screens in the brake ducts, side screens,
car went 11.23 at 123 in the 100 degree heat car has 10 second potential as is. without nitrous.
plan is 9's on the spray!
408 cui
trickflow heads,
comp nitrous cam,
callaway honker
