01 z28 built car whats it worth???
2001 camaro z28 black on black leather
motor is out of a 04 gto with a lpe 450hp package
ls6 heads and intake
bbk 80mm tb
Lingenfelter CNC cylinder head porting and polishing
- 2.02" / 1.57" stainless one piece valves
- Competition Cams dual valve springs, titanium retainers
- Three angle valve job, set spring heights, assemble heads
- Port matching of intake manifold
- Ported & polished throttle body
- Lingenfelter hydraulic roller camshaft- GT11 cam 215/231 .631/.634 118.0
- Lingenfelter high flow low restriction air intake system
- 160 degree thermostat
have all paperwork on motor and motor work
car has meziere elec water pump
fast fuel rails
msd plug wires
comp cams roller rockers 1.7
comp cams hi tec push rods
car has full bolt ons
has pacesetter coated headers &y pipe with a magnaflow cat back
car was a a4 car now converted to m6 trans has 63000 miles on it
clutch is a ls7 clutch kit, drill mod done
has a ktre 12 bolt with moser axles eaton hd posi unit and 4.11 gears also is a 3 inch steel driveshaft rated to 1000whp
full umi rear suspension non adj control arms on car adj panhard bar weld in 3 point subframe connectors
spohn pro series tunnel mount torque arm
umi front adj upper and lower control arms
all suspension parts are black
also has sam strano front and rear sway bars
eibach lowering springs pro kit has koni adj rear shocks and kyb adj fronts
racetronix fuel pump and hotwire kit
car has a sunoco hood on it
american racing tt2 wheels with like new tires 17x9.5 and 17x11 275 40 17 and 315 35 17
im sure im forgetting some small things but thats all i can think of for now
car made 434 wheel through a stalled auto running out of fuel from the stock fuel pump car should make 450 wheel through the 6 speed and new fuel system...im looking at selling the car and buying a vette so i was wondering how much i could get for the car the body has 164000 on it but looks like it has 80k on it it has a few scratches on it but i had all the little dings and dents removed when i got the car and had it detailed interior is clean drivers seat has one small tear in the bolster other than that the interior looks great...let me know what you guys think
bbk 80mm tb
fast fuel rails
msd plug wires
