testing the waters for my 2001 z28
got a 2001 z28 that im thinking about selling but wanted to see what kind of price tag she should have...
CAR: 2001 Camaro z28, black, and 3" harwood cowlhood, grey interior
MILEAGE: 80,XXX
ENGINE: LS1 with stock bottom end, trick flow cam 238/242 .598 lift, trick flow rods, comp valve springs, LS6 intake with 80mm Professional Products TB
EXHAUST: 1 3/4" Ceramic Coated Pacesetter LT's, offroad Y, and 40 series Flow in the a$$
DRIVETRAIN: T56 Stage 3 build from Lethal Performance in San Antonio, Tx and LS7 clutch each with about 5000 miles, and Pro 5.0 Short with 6" handle from ws6store
SUSPENSION: Eibach sportline springs, UMI k-member, subframe connectors, torque arm, lower control arms with relocators, and panhard rod
POWER ADDER: BRAND NEW never used but installed 10lb bottle NItrous Outlet GM EFI Dual Nozzle Systems with ash tray control panel, purge kit, and FJO-Digital Progressive Controller
REAREND: COMPLETELY STOCK
Haven't dynoed it out so dont know the numbers yet. So what can i expect if i sale her as is?
MILEAGE: 80,XXX
Also forgot to mention it has trick flow underdrive pulley and asp overdrive for alternator and allthe modifications were done in oct 09. I have all the receipts on hand and have about 4,XXX miles.
Again I'm not selling it but wanted to see what she could be worth if I did. Pic is my avatar. Thank you
