1997 Camaro 383
1997 Camaro 383
This is a feeler to see what I can get.
So here is what she has:
1997 Z28 6 speed
383 stroker with Eagle internals, 11:1 CR built by Golen racing
Custom Cam from Golen engines
Canton LT1 7 quart pan
New Aluminum oversized Radiator
Trickflow LT1 heads ported and polished up in Washington, NC ( Eddie do you remember the guys name that did them?)
ARP Studs
Gasket ported Intake, BBK 58mm TB
36lbs svo injectors
Comp pro mag roller rockers
Pace setter headers
Moser 9" 3.73 with spool set up by Kensil
Sphoon Drag Sway bar
MSD DIS 4
Delteq Opti Delete
A/C Delete with working heat and defroster
QA1 Shocks
Drag Springs
McCloed Street twin Clutch
Weld Prostars W/ Mikey Tompson wheels
TTII avalilble also
BMR upper and lower A-Arms
Sphoon K-member
Strange Drag brakes (Front)
Bolt in Roll cage
Tuned by RPM in Garner NC
http://s23.photobucket.com/albums/b4...t=100_2211.flv
1997 Z28 6 speed
ARP Studs
36lbs svo injectors
Pace setter headers
MSD DIS 4
Delteq Opti Delete
QA1 Shocks
Drag Springs
TTII avalilble also
Sphoon K-member
Bolt in Roll cage
