2000 Camaro Z-28, 6-speed
formerly 2000blackcamaross (6-25-2013)
2000 Camaro Z-28 with t-tops
49,9xx miles
4,xxx miles on drivetrain
prior salvage title
Motor:
-Forged 346 short block from SDPC
-Patriot stage3 heads , 64cc, flow 309.6 CFM and 224.1 CFM @.600
-Comp Cams .571/.574 228/232 cut on 112+4
-Comp Cams chromemoly pushrods
-Comp Cams lifters
-LS6 Intake painted gloss black
-85mm TB
-Hypertech 160 thermostat
-MSD 8.5mm
-ARP bolts
-TB bypass
-SLP lid with K&N filter
-Smooth Bellow
-SLP Heavy Duty Oil Pump
-SLP double row timing chain
Drivetrain:
-New stock Clutch master cylinder
-New stock Through out
-T56 rebuild (could send the build sheet)
-Spec flywheel/stage 3 clutch
-Pro 5.0 shifter
-Hurst pistol grip
-Stock 10 bolt with 4:10 gears
Suspention:
-Hotchkis springs
-Bilstein HD shocks
-Spohn TA with two drive shaft safty loops
-SLP SFC
-Polyurathane trans.mount
-UMI adj. LCA's in red
-BMR adj. PHB in red
Exhaust:
-Pacesetter long tube headers
-pacesetter of road Y-pipe
-LM1 catback
Fuel system:
-racetronix fuel pump
-SB lines from hard line to fuel rails
-Fuel rails(can't Rember the brand )
-42LB. injectors
Extras:
-AEM wideband
-C6 Wheels
-5% window tint on hatch and 15% on side windows
-SLP linelock
-SS spoiler
-Radio antenna removed and filled
-Halo head lights
-tinted corner lights front and rear
-Billit Grille
-Camaro inserts
-Optama battery
I am sure there is more that I can't remember right now
The car is dirty but here are the Pics:
I this pic the line on the rear corner is not a scratch it was starting to rain and thats what it is.
49,9xx miles
prior salvage title
Motor:
-Comp Cams lifters
-85mm TB
-MSD 8.5mm
-ARP bolts
-TB bypass
-Smooth Bellow
Drivetrain:
-Pro 5.0 shifter
-Hurst pistol grip
Suspention:
-Hotchkis springs
-Bilstein HD shocks
-SLP SFC
Exhaust:
-LM1 catback
Fuel system:
-42LB. injectors
Extras:
-AEM wideband
-C6 Wheels
-SLP linelock
-SS spoiler
-Halo head lights
-Billit Grille
-Camaro inserts
-Optama battery
