2000 NBM z28 m6
2000 NBM z28 m6
car has 93k on it. car is real clean for 93k ss hood and spoiler, slp bowtie grille, TTIIs with 315s in back and 275s in front. now for the important mods
347 with forged pistons and rod bolts
stage 2.5 ls6 heads pac dual springs
232/236 cam on a 112
fast 92/92 intake and throttle body
racetronix 37lb and hour injectors
slp lid w k&n
pacesetter long tubes with ory and slp dual dual exhaust
stage 1 trans from t56 rebuilders ls7 clutch ws6 store short stick, hurst shifter
steel driveshaft (custom made)
moser 12 bolt with 33 splines and 3.90 gears and detroit true trac
a umi trans mounted torque arm
umi adj panhard rod
spohn 22 mm rear sway bar
the transmission has about 15k on it the rearend about 10k the clutch about 5k. the motor has about 4k on it. ran it when it was real cold and went 12.2 at 119. real bad 60'. im sure im forgetting something butt... ill try and post some recent pics. whats it worth?
slp lid w k&n
umi adj panhard rod
Not sure what it would be worth but would you possibly be interested in a trade?
https://ls1tech.com/forums/vehicle-c...de-m6-ls1.html
