Found a 2000 LS1 with auto trans, is this a good price?
Found a motor and trans (4L60E) from a 2000 Z28 with harness complete and all accessories, trans yolk to serpantine belt, including the O2 sensors..70K miles
Would you pay $2700 for this?
I am swapping an LS1 in place of my turbocharged 2RZ, moving on to bigger and better things
It seems after all the research I have done that it would be a good starting point...
I was going to swap in the 1GR FE Toyota motor but didnt work out, besides thats only a 4.0 V6, I would rather start of with 5.7 and go from there..
I want to post a build like I did when I was doing the 1 GR, already removed my core support to facilitate fitting..
thanks for your help guys, I think I am going to get this...I just wanted the reassurance from complete strangers, lol, no but really would like some input with any info that might help..
Is this a good deal?
Wow thats a great price! It seems that in So Cal the going rate is $2700 for motor and trans complete, I have a 700R4 build laying around, but it needs some clutches, so I just wanted to go with the stock 4L60E for now since it is complete and I know everything should work, I am just lears of making this purchase because I need to be sure I have everything, A/C lines P/S lines, everything I need to mate it up to my Tacoma setup, its all the little stuff that nickle and dimes you to death, trying to keeo that to a minumum, I have done stuff like this before and you had better be sure to get more than everything to be sure...too much is better that not enough in this case..
