2000 Z/28 Drag Roller?
ok so i was thinking about switching projects, not sure yet, was wondering what someone would offer me for this first.
Every bit of the suspension is brand new, never even had the cars weight on it yet. Except the Torque arm set up.
The 12 bolt Has been rebuilt and sealed, never even had fluid in it yet
th400 is built, and comes with a brand new Neil Chance 5500 stall convertor, the conversion piece to make your speedometer work, and a brand new flex plate
What I have:
2000 Z/28 Black Ttop car
12 point chromoly cage
Spohn Chromoly suspension: Upper and lower A arms (rod ended), K member, Body Mount Torque Arm, solid motor mounts, dbl adj LCa's, dbl adj PHB
Manual rack conversion
Hals double adjustable fronts
Hals double adjustable COIL OVER rears
Moser 33 spline 3.73 full spool rear
BMR extreme drag sway bar
Bogarts 15x10/15x3.5 great tires
Kirkey seat (brand new unopened cover), wolf bolt in kit and crotch bar
cheetah gated shifter
Hawk pads brand new
stainless steel brake lines brand new
slotted drilled rotors
Also included:
manual window conversion kit
Aluminum door panels
dual in tank walboros
Kooks 2" LS7 to F-body headers and 3.5" Y pipe (I paid $1500)
I have receipts for just about everything, I have a ton in the brand new unused suspension alone. i tihnk I am close to $20k as it sits
Cage should be good for 8.5 cert
I am sure there is other misc parts I am forgetting, but i think you get the idea.
I would be selling every single thing you would need to get the car racing except:
a motor
driveshaft
engine harness
upgraded fuel lines
seatbelt harness
What I have:
Hawk pads brand new
Also included:
a motor
driveshaft
engine harness
upgraded fuel lines
seatbelt harness
