opinions on value for my 98 T/A
I purchased this car from a friend a few months ago to help him out since his wife was 9 months pregnant and he needed the cash to get a reliable daily to haul the kid around and I always liked the car.
anyway
98 trans am 101,xxx miles
stock LS1 short block
LS6 cam and springs installed with LS7 lifters and ported 5.3 heads with LS1 valves at 95k miles
recently installed LS6 manifold with correct coolant rear block offs and front cross over line
all emissions equipment deleted and tuned on E85 with GTP 42 lbhr injectors
factory exhaust manifolds and y pipe with converters deleted and a borla catback with QTP cutour
I recently replaced the T-56 with a remanufactered unit with approx 2k miles on it, the car has a textarila 6 puck with probably 30-40k miles of street driving but was in good visual condition when I replaced the transmission.
3.42 axle from 98 SS camaro with approx 25k miles on it.
The exterior is 8.5/10 and interior is 9/10 absolutely everything on the car works great
I have also replaced all the brakes, power steering lines and gone through the car with a fine toothed comb it's in absolutely pristine mechanical condition (I'm an ASE master tech and chevy master tech) and I'm going to have the paint professionally buffed and waxed.
pics
http://s219.photobucket.com/user/Pon...06775855422794
I have the OEM 16s plus the 18" c6 z06 wheels, along with the original heads, LS1 intake, front cover, BMR frame connectors and spare radio and 12 disc changer, spare set of T-tops.
Anyway this is serriously the nicest LS1 trans am I've seen in years and it does pain me to sell it, but it needs to find a new home if I'm going to finish my 91 Z28 that has been a long time project. I was thinking about asking 9500 for the car with both sets of wheels and all the additional parts. thoughts???
anyway
pics
$9500 is about $2500 higher than book value. The modifications will limit your buying market and typically add little value to the car. Then you have to consider what you are selling against: right now there are plenty of sub-100k mile LS1 cars on the market with asking prices at or lower than $9500.
I really like the looks of your T/A with that color, and the wheels too. You sure you don't want to keep it after all that work??
Asking $9,500 isn't outrageous at all considering that you are a certified mechanic and feel comfortable with everything. Still, I think a buyer will be found closer to $8,000 after all is said and done. GLWS!!
