Help me set a price please-1999 Z28/383
Not sure if it's even worth selling. But if I did, what should I look at listing it at? Thanks, Chris.
56,xxx miles, second owner, original interior, both interior and exterior in great shape and always stored in climate controlled garage.
Engine:
383 CI LS1 V8 Rebuilt at 54,810 mi.
3.905 Bore
Callies Compstar 4” Crank
Callies Compstar 6.125” Connecting Rods
ACL Rod and Main Bearings
Diamond -2cc Flat Top Pistons and Rings
ARP Main Studs, Head Studs and Balancer Bolt
ASP Underdrive Pulley
LS7 Lifters and LS2 Lifter Trays
Cylinder Head Specialties Stage 2 - 5.7 LS1 241 Heads
(REV 2.02 intake, 1.57 exhaust valves, & Patriot dual gold springs(valve drop .105 and .135 milled .030 with 64cc chambers and flowing 299 In and 224 Ex at .600 lift))
GM LS2 MLS Head Gaskets (4.020/0.051)
Futral Motorsports .236/.244 (Dur.) .600/.595(Lift) 114+4 (LSA)
Comp Cam Chromeoly Pushrods
Rollmaster Dual Roll Timing Chain
Yella Terra 1.7 Roller Rockers
Energy Suspension Endlinks Set
Hypertech 160' Thermostat
SLP Heavy Duty Oil Pump
Thunder Racing Coil Pack Relocation Kit
Taylor 10 m.m. Plug Wires
NGK TR55 Spark Plugs
FAST Fuel Rails with FAST Mechanical Fuel Gauge
Racetronix 42lb./hr. Fuel Injectors
Racetronix 255L/Hr. In-Tank Fuel Pump with Hotwire kit
HP Tuners SD Tune by Justune
Intake:
FAST LSXR 102mm Intake
Nick Williams 102mm Throttle Body
SLP 85mm Mass Air Flow Sensor
SLP Flo-Pac
Exhaust:
Jet Hot Coated Hooker Headers
" " Y-Pipe
" " Exhaust
" " McCord Electric Race Ready Cut-Out
Transmission:
Stage IV Speed Inc. Max Evil Transmission
Energy Suspension Trans. Mount
TCI 3500 Stall Converter
B&M Supercooler
Rear End:
3.73 GM Motive Gears
TA Performance Rear End Girdle
Suspension:
Eibach Pro Kit
UMI Bolt-In 3-Point Subframe Connectors
UMI Lower Control Arms
Other:
Drilled & Slotted Ri Rotors
18x9.5 Y2K Vette Wheels
285-35-18 Nitto NT555 Extreme Performance Tires
Engine:
3.905 Bore
Intake:
SLP Flo-Pac
Exhaust:
" " Y-Pipe
" " Exhaust
Transmission:
B&M Supercooler
Rear End:
Suspension:
Eibach Pro Kit
Other:
